跳转到主内容
Sony Xperia E3 Touch Screen Replacement
你所需要的
视频概述
  1. Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: 步骤 1 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: 步骤 1 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement, Turn of the Phone: 步骤 1 中的图像 3,3
    • Turn off the device
    • Remove the SIM and the memory cards.
    • Remove 4x rubber corners.
    • There are 6x black screws Torx T4, remove them.
  2. Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: 步骤 2 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: 步骤 2 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement, Rear Cover Removal: 步骤 2 中的图像 3,3
    • Use a plastic tool and separate the rear bezel.
    • Be careful for the side buttons.
  3. Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: 步骤 3 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: 步骤 3 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement, Touch Screen Flex Cable: 步骤 3 中的图像 3,3
    • Disconnect the touch screen flex cable.
    • Disconnect the battery flex cable.
  4. Sony Xperia E3 Touch Screen Replacement: 步骤 4 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement: 步骤 4 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement: 步骤 4 中的图像 3,3
    • With a hair dryer or heat gun warm the glass, at first for about 2-3 minutes.
    • Use a thin plastic tool, like a plastic pick and start the separation from the underside.
    • Do this very slow and periodically warm the glass!
    • At the beginning you have to separate the touch screen glass from the main frame.
  5. Sony Xperia E3 Touch Screen Replacement: 步骤 5 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement: 步骤 5 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    购买
    • Now continue with a plastic card.
    • AGAIN!!! Very slowly and periodically worm the glass.
    • The LCD is thin less than a millimeter!
    • Remove the touch screen.
  6. Sony Xperia E3 Touch Screen Replacement: 步骤 6 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement: 步骤 6 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement: 步骤 6 中的图像 3,3
    • Now is time to test the phone.
    • If the LCD is OK you can order only a touch screen, if no, then you need display assembly - touch screen & LCD
    • With a plastic pick gently scrape the glue.
    • With a cloth and isopropyl alcohol clean the LCD.
    • Don't use a lot of alcohol. if the liquid passes behind the LCD, will appear spots that you can't remove.
  7. Sony Xperia E3 Touch Screen Replacement: 步骤 7 中的图像 1,3 Sony Xperia E3 Touch Screen Replacement: 步骤 7 中的图像 2,3 Sony Xperia E3 Touch Screen Replacement: 步骤 7 中的图像 3,3
    • On the new touch screen or on the main frame put adhesive sticker 3mm.
    • Be careful not to cover the the places for the camera, sensor, earpiece, etc.
    • Lift the logic board a little bit, so that the touch screen flex cable can pass.
    • It's easier if you can order the touch screen together with adhesive which is cut off specifically for model.
  8. Sony Xperia E3 Touch Screen Replacement: 步骤 8 中的图像 1,1
    • Reassemble the device.
    • That's all.
结论
6等其他人完成本指南。
ZFix
于12/09/13注册
191,308 声望
创作了330篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 10
总计 7,971
