跳转到主内容
Sony XPERIA Tablet Z Screen Replacement
你所需要的
  1. Sony XPERIA Tablet Z Screen Replacement, Screen: 步骤 1 中的图像 1,3 Sony XPERIA Tablet Z Screen Replacement, Screen: 步骤 1 中的图像 2,3 Sony XPERIA Tablet Z Screen Replacement, Screen: 步骤 1 中的图像 3,3
    • Remove the back cover by lifting up one corner using the plastic opening tool, and then removing the adhesive around the cover.
  2. Sony XPERIA Tablet Z Screen Replacement: 步骤 2 中的图像 1,3 Sony XPERIA Tablet Z Screen Replacement: 步骤 2 中的图像 2,3 Sony XPERIA Tablet Z Screen Replacement: 步骤 2 中的图像 3,3
    • Gently separate the gold ribbon cable from the back side by lifting up with plastic opening tool and separating from the adhesive.
    • Separate the black ribbon cable from the back of screen by lifting up with a plastic opening tool.
  3. Sony XPERIA Tablet Z Screen Replacement: 步骤 3 中的图像 1,1
    • Use a hairdryer, heat gun, or something suitable to heat the edge of the screen to soften the adhesive holding the screen.
    • Only heat enough to loosen the adhesive but not damage the tablet.
  4. Sony XPERIA Tablet Z Screen Replacement: 步骤 4 中的图像 1,1
    • Gently pry the edge of the screen working around while heating.
  5. Sony XPERIA Tablet Z Screen Replacement: 步骤 5 中的图像 1,1
    • Clean adhesive from perimeter of frame to prepare for new screen.
结论
8等其他人完成本指南。
Gustavo Correa
于07/11/17注册
373 声望
撰写一个指南
团队
IUPUI, Team S5-G1, Harley Summer 2017 IUPUI, Team S5-G1, Harley Summer 2017 的会员
IUPUI-HARLEY-SU17S5G1
4 名成员
创作了3篇指南
5条评论
اريدشراءاريدشراءشاشه جديده
kore ares - 回复
Do you need adhesive to attach new screen, & if so, what do you use?
Martha Morrison - 回复
i would also like to know what adhesive you use to reatach the screen. thanks
Blaze - 回复
Wooo its self explanatory.Good work
Duncan Mwaniki - 回复
Where do I get the Screen if I'm in South Africa
Thembekile Nizel - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 56
总计 6,924
