跳转到主内容
加入维修社区 - 创建账户
Sony XPERIA Tablet Z Motherboard Replacement
你所需要的
  1. Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the back cover by using the plastic opening tools.
  2. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 2 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 2 中的图像 2,2
    • Disconnect the battery by lifting the connector straight up from the motherboard with a plastic opening tool or equivalent.
    • Do not pry on the wires. Only pry up on the white plastic part of the connector that is closest to the battery itself.
  3. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 3 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry up the tape and ribbon cable connector for front facing camera.
    • Remove front facing camera and cables.
  4. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 4 中的图像 1,1
    • Slide the ribbon cable out of motherboard.
    • This cable is the only one in this guide that slides out from the motherboard in a motion that is parallel to the motherboard.
  5. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 5 中的图像 1,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 5 中的图像 2,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips head #0 screwdriver to remove the 3.06 mm screws from the Micro USB retaining plate.
    • Remove the cover plates.
    • There is plastic plate and a metal one.
    • Remove the USB port partially from its position. It can stay connected just moved out of the way.
  6. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 6 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips head #0 screw driver to remove the 3.43 mm screws on the volume control retaining plate.
    • Remove the volume control.
  7. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift up the connector for the rear facing camera.
    • Remove the rear facing camera.
  8. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 8 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips head #0 screwdriver to remove the 3.43mm cover plate screws for headphone port, power button, and status LED assembly.
    • Remove headphone port, power button, and status LED assembly cover plate.
  9. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 9 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the connectors for the headphone port, power button, LED from the mother board.
    • Remove the headphone port, power button, and LED from the mother board.
  10. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 10 中的图像 1,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 10 中的图像 2,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 10 中的图像 3,3
    • Disconnect the 3 ribbon cable connectors from the mother board near the USB port and speaker.
  11. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard by gently prying up. Once it is loosened from the adhesive you may need to slide it away from the battery while lifting.
结论
3等其他人完成本指南。
团队
IUPUI, Team S5-G1, Harley Summer 2017 IUPUI, Team S5-G1, Harley Summer 2017 的会员
IUPUI-HARLEY-SU17S5G1
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 35
总计 2,482
