跳转到主内容
加入维修社区 - 创建账户
Sony XPERIA Tablet Z Motherboard Replacement
你所需要的
  1. Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: 步骤 1 中的图像 2,3 Sony XPERIA Tablet Z Motherboard Replacement, Motherboard: 步骤 1 中的图像 3,3
    • Remove the back cover by using the plastic opening tools.
    询问修复机器人
    添加评论
  2. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 2 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 2 中的图像 2,2
    • Disconnect the battery by lifting the connector straight up from the motherboard with a plastic opening tool or equivalent.
    • Do not pry on the wires. Only pry up on the white plastic part of the connector that is closest to the battery itself.
    询问修复机器人
    添加评论
  3. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 3 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 3 中的图像 2,2
    • Pry up the tape and ribbon cable connector for front facing camera.
    • Remove front facing camera and cables.
    询问修复机器人
    添加评论
  4. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 4 中的图像 1,1
    • Slide the ribbon cable out of motherboard.
    • This cable is the only one in this guide that slides out from the motherboard in a motion that is parallel to the motherboard.
    询问修复机器人
    添加评论
  5. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 5 中的图像 1,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 5 中的图像 2,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a Phillips head #0 screwdriver to remove the 3.06 mm screws from the Micro USB retaining plate.
    • Remove the cover plates.
    • There is plastic plate and a metal one.
    • Remove the USB port partially from its position. It can stay connected just moved out of the way.
    询问修复机器人
    添加评论
  6. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 6 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 6 中的图像 2,2
    • Use a Phillips head #0 screw driver to remove the 3.43 mm screws on the volume control retaining plate.
    • Remove the volume control.
    询问修复机器人
    添加评论
  7. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 7 中的图像 1,1
    • Lift up the connector for the rear facing camera.
    • Remove the rear facing camera.
    询问修复机器人
    添加评论
  8. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 8 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 8 中的图像 2,2
    • Use a Phillips head #0 screwdriver to remove the 3.43mm cover plate screws for headphone port, power button, and status LED assembly.
    • Remove headphone port, power button, and status LED assembly cover plate.
    询问修复机器人
    添加评论
  9. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 9 中的图像 1,2 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 9 中的图像 2,2
    • Disconnect the connectors for the headphone port, power button, LED from the mother board.
    • Remove the headphone port, power button, and LED from the mother board.
    询问修复机器人
    添加评论
  10. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 10 中的图像 1,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 10 中的图像 2,3 Sony XPERIA Tablet Z Motherboard Replacement: 步骤 10 中的图像 3,3
    • Disconnect the 3 ribbon cable connectors from the mother board near the USB port and speaker.
    询问修复机器人
    添加评论
  11. Sony XPERIA Tablet Z Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the motherboard by gently prying up. Once it is loosened from the adhesive you may need to slide it away from the battery while lifting.
    询问修复机器人
    添加评论
结论
取消:我没有完成这个指南。
3等其他人完成本指南。
团队
IUPUI, Team S5-G1, Harley Summer 2017 IUPUI, Team S5-G1, Harley Summer 2017 的会员
IUPUI-HARLEY-SU17S5G1
4 名成员
创作了3篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 32
总计 2,613
