跳转到主内容
加入维修社区 - 创建账户
Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement
你所需要的
  1. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: 步骤 1 中的图像 1,3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: 步骤 1 中的图像 2,3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement, Remove the back cover: 步骤 1 中的图像 3,3
    在这个步骤中使用的工具:
    • Tools you will need is the Phillips #00 precision screwdriver, Plastic Opening Tools, and tweezers.
    • Insert plastic opening tool in the corner of device and slide along edges to separate adhesive.
    • Remove cover
  2. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 步骤 2 中的图像 1,3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 步骤 2 中的图像 2,3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 步骤 2 中的图像 3,3
    • Remove tape connecting front camera to motherboard and then disconnect the camera from the port.
    • Lift the camera from the right and simply wiggle out of the slot.
  3. Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 步骤 3 中的图像 1,3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 步骤 3 中的图像 2,3 Sony XPERIA Tablet Z Front and Rear Facing Cameras Replacement: 步骤 3 中的图像 3,3
    • Disconnect the back camera from the port located in the upper right corner.
    • Lift up the camera cable using the tweezers.
    • Wiggle out camera from the slot.
结论
2等其他人完成本指南。
Martin Luna
于09/24/14注册
1,873 声望
创作了5篇指南
团队
USF Tampa, Team 15-6, Remmell Fall 2014 USF Tampa, Team 15-6, Remmell Fall 2014 的会员
USFT-REMMELL-F14S15G6
3 名成员
创作了7篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 21
过去 30 天: 72
总计 3,244
