跳转到主内容
Sony XDR-S50 DAB Radio DAB Module Removal
  1. Sony XDR-S50 DAB Radio DAB Module Removal, Opening the case: 步骤 1 中的图像 1,2 Sony XDR-S50 DAB Radio DAB Module Removal, Opening the case: 步骤 1 中的图像 2,2
    • Remove the batteries.
    • Remove 4 cross-head screws from the rear of the case and a fifth in the battery compartment.
    • The back should now lift off.
    • A wire is still connecting the aerial to the main circuit board. Do not strain it unduly.
  2. Sony XDR-S50 DAB Radio DAB Module Removal, Disconnecting the aerial: 步骤 2 中的图像 1,2 Sony XDR-S50 DAB Radio DAB Module Removal, Disconnecting the aerial: 步骤 2 中的图像 2,2
    • Remove the aerial retaining screw.
    • Lift the aerial slightly in order to release the aerial connecting tag. You can now put the case rear cover aside.
  3. Sony XDR-S50 DAB Radio DAB Module Removal, Removing the knobs: 步骤 3 中的图像 1,2 Sony XDR-S50 DAB Radio DAB Module Removal, Removing the knobs: 步骤 3 中的图像 2,2
    • Pull off the volume knob.
    • To remove the tuning knob, gently prise it off with a jimmy.
    • Under the tuning knob you will see a spring. Note its position for reassembly and remove it, taking care it doesn't take flight.
  4. Sony XDR-S50 DAB Radio DAB Module Removal, Releasing the midframe: 步骤 4 中的图像 1,1
    • Unsolder the two wires connecting to the loud speaker. (This is not essential but will save you from straining these wires.)
    • Remove 2 screws from the grey midframe, one on the lower right on the battey connector and the other on the upper left above the tuning knob.
    • Release the two cables from their retaining clips under the battery compartment.
  5. Sony XDR-S50 DAB Radio DAB Module Removal, Removing the midframe: 步骤 5 中的图像 1,1
    • Lift the grey battery connector slightly to disengage a bush where you removed a screw in the previous step. (On reassembly, ensure this is snapped back in place.)
    • Ease the power and headphone sockets out of their holes in the case, using a spudger or similar tool.
    • You can now lift the midframe and attached assemblies out of the case, first lifting the right hand side by the power and headphone sockets, and hence withdrawing the volume and tuning spindles from the left hand side.
    • Before reassembly it's worth dusting the LCD display and the inside of the display window.
  6. Sony XDR-S50 DAB Radio DAB Module Removal, Sony XDR-S50 DAB Radio DAB Module Removal: 步骤 6 中的图像 1,3 Sony XDR-S50 DAB Radio DAB Module Removal, Sony XDR-S50 DAB Radio DAB Module Removal: 步骤 6 中的图像 2,3 Sony XDR-S50 DAB Radio DAB Module Removal, Sony XDR-S50 DAB Radio DAB Module Removal: 步骤 6 中的图像 3,3
    • Unsolder the connection on thecircuit board to the DAB tuner module below.
    • Remove two screws marked on the circuit board (marked on the board with arrows).
    • The circuit board is attached to the DAB radio module beneath by a multi-way connector. Gently lift the right hand side of the board in order to release it.
    • The DAB radio module will now simply lift out.
  7. Sony XDR-S50 DAB Radio DAB Module Removal: 步骤 7 中的图像 1,1
    • You can now inspect the DAB module.
结论
Philip Le Riche
于02/18/14注册
31,534 声望
创作了47篇指南
团队
Restart Project Restart Project 的会员
Local Repair Groups
25 名成员
创作了375篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 16
总计 812
