跳转到主内容
Sony Walkman WM-AF48 Power Switch Replacement
你所需要的
  1. Sony Walkman WM-AF48 Power Switch Replacement, Getting started: 步骤 1 中的图像 1,1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: 步骤 2 中的图像 1,3 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: 步骤 2 中的图像 2,3 Sony Walkman WM-AF48 Power Switch Replacement, Remove the outer cover: 步骤 2 中的图像 3,3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: 步骤 3 中的图像 1,2 Sony Walkman WM-AF48 Power Switch Replacement, Remove the motherboard: 步骤 3 中的图像 2,2
    • Gently pull the ribbon from the jack above the film revolver, near the edge.
    • Lift the motherboard from the outer shell.
    • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
  4. Sony Walkman WM-AF48 Power Switch Replacement, Remove the power switch: 步骤 4 中的图像 1,1
    • Identify the six points where the power switch is soldered to the motherboard.
    • Using a soldering iron, remove the switch by de-soldering these points which hold it in place.
结论
另外一个人完成了本指南。
团队
一条评论
Hi,
Where would you find a Vintage Sports Sony Walkman power switch ? Battery light is on one function and then turns off on the other. Other than this, the unit is in EXCELLENT Condition. THANKS for any insight and for helping us :)
Pamela Osborne - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 2,017
