跳转到主内容
Sony Walkman WM-AF48 Headphone Jack Replacement
你所需要的
  1. Sony Walkman WM-AF48 Headphone Jack Replacement, Getting started: 步骤 1 中的图像 1,1
    • Remove any batteries or cassettes from the Walkman.
  2. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: 步骤 2 中的图像 1,3 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: 步骤 2 中的图像 2,3 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the outer cover: 步骤 2 中的图像 3,3
    • Using a spudger, separate the back cover from the front.
    • Remove the back cover evenly on all sides. The best method is to insert the spudger and gently twist it slightly to separate the two parts, slowly working your way around the entire outer shell.
  3. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the motherboard: 步骤 3 中的图像 1,2 Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the motherboard: 步骤 3 中的图像 2,2
    • Gently pull the ribbon from the jack just above the film revolver, near the edge.
    • Carefully lift the motherboard out of the outer shell.
    • Be careful to only handle the motherboard by the edges. Avoid touching the metal parts.
  4. Sony Walkman WM-AF48 Headphone Jack Replacement, Remove the headphone jack: 步骤 4 中的图像 1,1
    • Locate the four metal points on the motherboard that hold the headphone jack in place.
    • Using a soldering iron, remove the headphone jack by de-soldering the four points that hold it in place.
结论
7等其他人完成本指南。
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 24
总计 5,516
