跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Sony Walkman WM-4,请使用我们的维修手册
  1. Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: 步骤 1 中的图像 1,2 Sony Walkman WM-4 Teardown, Sony Walkman WM-4 Teardown: 步骤 1 中的图像 2,2
    • Flip the Sony Walkman so that its rear side faces you.
    • Use a screwdriver to remove the two screws from the surface of the Walkman.
    • Press the battery plate slightly with your thumb and slide it downwards. This will open the battery compartment.
    • Remove the batteries from the Walkman.
  2. Sony Walkman WM-4 Teardown: 步骤 2 中的图像 1,2 Sony Walkman WM-4 Teardown: 步骤 2 中的图像 2,2
    • Turn over your Walkman and gently press the cover to open the cassette holder.
    • When the cassette holder is opened, you can see two more screws.
    • Using a screwdriver, remove the two screws.
  3. Sony Walkman WM-4 Teardown: 步骤 3 中的图像 1,2 Sony Walkman WM-4 Teardown: 步骤 3 中的图像 2,2
    • Use a plastic opening tool or a spudger to push the tabs. This will remove the cover and open the Walkman.
    • Be careful so you dont break the tabs!
    • Once the Walkman is opened, you can troubleshoot for any issues, remove the old wires and attach new ones, or even reassemble the Walkman.
lenzo
于07/14/11注册
125 声望
撰写一个指南
一条评论
Drive belt trashed any ideas where to get one?
nz-tiger - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 19
过去 30 天: 43
总计 15,937
