跳转到主内容
Sony Walkman NWZ-S764 Bluetooth module Replacement
你所需要的
  1. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: 步骤 1 中的图像 1,3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: 步骤 1 中的图像 2,3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the back cover: 步骤 1 中的图像 3,3
    • Remove the two black 6.4mm Phillips screws from the back of the device.
  2. Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 2 中的图像 1,3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 2 中的图像 2,3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 2 中的图像 3,3
    • Using a plastic opening tool, work your way around the edges of the device, carefully prying off the front panel.
  3. Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 3 中的图像 1,2 Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 3 中的图像 2,2
    • Remove the two 2.8 mm phillips screws located on either side of the device near the top.
  4. Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 4 中的图像 1,2 Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 4 中的图像 2,2
    • Carefully pull the top piece away from the device.
  5. Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: 步骤 5 中的图像 1,3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: 步骤 5 中的图像 2,3 Sony Walkman NWZ-S764 Bluetooth module Replacement, Removing the Bluetooth module: 步骤 5 中的图像 3,3
    • Use the flat end of the spudger to flip up the retaining flap for the bluetooth module.
    • Be sure to lift up on the retaining flap, and not the socket itself.
  6. Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 6 中的图像 1,3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 6 中的图像 2,3 Sony Walkman NWZ-S764 Bluetooth module Replacement: 步骤 6 中的图像 3,3
    • Remove the two 1.8mm silver Phillips screws on the Bluetooth module.
    • Lift up on and remove the Bluetooth module.
    • The ribbon cable must first be removed in order to access the highlighted screw.
结论
John Ferguson
于01/21/15注册
657 声望
创作了5篇指南
团队
USF Tampa, Team 4-2, Brown Winter 2015 USF Tampa, Team 4-2, Brown Winter 2015 的会员
USFT-BROWN-W15S4G2
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 661
