简介
This guide will walk you through the steps to removing and replacing the headphone audio jack on the walkman.
你所需要的
Remove the two black 6.4mm Phillips screws from the back of the device.
Remove the two 2.8mm silver Phillips screws on the sides of the frame.
Insert a plastic prying tool between the bottom of the case and the motherboard.
Pry up the assembly and lift it away from the case.
即将完成!
结论
2等其他人完成本指南。
