跳转到主内容
Sony Walkman NWZ-E438 USB Port Replacement
你所需要的
  1. Sony Walkman NWZ-E438 USB Port Replacement, Disassembling Sony Walkman NWZ-E438: 步骤 1 中的图像 1,1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 USB Port Replacement: 步骤 2 中的图像 1,1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: 步骤 3 中的图像 1,3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: 步骤 3 中的图像 2,3 Sony Walkman NWZ-E438 USB Port Replacement, Circuit Board: 步骤 3 中的图像 3,3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 USB Port Replacement: 步骤 4 中的图像 1,2 Sony Walkman NWZ-E438 USB Port Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 USB Port Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 USB Port Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the circuit board from the device.
  7. Sony Walkman NWZ-E438 USB Port Replacement, USB Port: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Using fine point tweezers, push them between the chip and USB port.
  8. Sony Walkman NWZ-E438 USB Port Replacement: 步骤 8 中的图像 1,1
    • Slowly pry the USB port off of the chip.
    • You will need to solder the new USB onto the circuit board.
  9. Sony Walkman NWZ-E438 USB Port Replacement: 步骤 9 中的图像 1,1
    • Remove USB port.
结论
一条评论
Wher buy new port????pavel87cz@gmail.com
Pavel Drobny - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 596
