跳转到主内容
Sony Walkman NWZ-E438 Screen Replacement
你所需要的
  1. Sony Walkman NWZ-E438 Screen  Replacement, Disassembling Sony Walkman NWZ-E438: 步骤 1 中的图像 1,1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Screen  Replacement: 步骤 2 中的图像 1,1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Screen  Replacement, Screen: 步骤 3 中的图像 1,1
    • Pull up the 2 copper strips connecting the outside of the device to the inside of the device.
  4. Sony Walkman NWZ-E438 Screen  Replacement: 步骤 4 中的图像 1,1
    • Using the small, plastic prying tool wedge it between the bottom of the frame and the outer frame.
    • Slowly circle the device, popping the outside of the frame off.
  5. Sony Walkman NWZ-E438 Screen  Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • To remove the screen, use the fine point tweezers and lift up on the metal piece at the bottom of the frame.
  6. Sony Walkman NWZ-E438 Screen  Replacement: 步骤 6 中的图像 1,1
    • To remove screen from metal backing, use fine point tweezers to go in between the screen and metal backing and slowly pull them apart.
  7. Sony Walkman NWZ-E438 Screen  Replacement: 步骤 7 中的图像 1,1
    • The screen will be removed.
结论
一条评论
wher buy display
Pavel Drobny - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 686
