跳转到主内容
Sony Walkman NWZ-E438 Headphone Jack Replacement
你所需要的
  1. Sony Walkman NWZ-E438 Headphone Jack Replacement, Disassembling Sony Walkman NWZ-E438: 步骤 1 中的图像 1,1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Headphone Jack Replacement, Headphone Jack: 步骤 3 中的图像 1,1
    • Unscrew the 1 screws around the headphone jack using Phillips PH000 screwdriver.
  4. Sony Walkman NWZ-E438 Headphone Jack Replacement: 步骤 4 中的图像 1,2 Sony Walkman NWZ-E438 Headphone Jack Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using the fine pointed tweezers, unplug the cords connecting the headphone jack to the chip.
  5. Sony Walkman NWZ-E438 Headphone Jack Replacement: 步骤 5 中的图像 1,3 Sony Walkman NWZ-E438 Headphone Jack Replacement: 步骤 5 中的图像 2,3 Sony Walkman NWZ-E438 Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Remove the headphone jack.
结论
2条评论
hi there, i have mine apart but where do i get a spare one to refit, please help
lee manock - 回复
Can you make a tutorial on how to replace the headphone jack on the sony nwz-s774?
petermedz - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 14
总计 824
