跳转到主内容
Sony Walkman NWZ-E438 Device Circuit Board Replacement
你所需要的
  1. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Disassembling Sony Walkman NWZ-E438: 步骤 1 中的图像 1,1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 步骤 2 中的图像 1,1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: 步骤 3 中的图像 1,3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: 步骤 3 中的图像 2,3 Sony Walkman NWZ-E438 Device Circuit Board Replacement, Circuit Board: 步骤 3 中的图像 3,3
    • First, you must remove the black tape on the circuit board.
    • Next, pull up on the red and gold band until it detaches from the chip.
  4. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 步骤 4 中的图像 1,2 Sony Walkman NWZ-E438 Device Circuit Board Replacement: 步骤 4 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a small plastic prying tool, slip the end under the device circuit board and slowly lift it.
    • Once the circuit board is lifted, carefully remove the chip with tweezers.
    • The circuit board will still be connected to the device by a wire.
  5. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 步骤 5 中的图像 1,1
    • Using a soldering iron, carefully heat the metal connecting the wires from the device to the circuit board.
    • You will need the soldering iron to reattach those wires once you've replaced the circuit board.
  6. Sony Walkman NWZ-E438 Device Circuit Board Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the circuit board from the device.
结论
For reassembling your device, follow the instructions in reverse.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 531
