跳转到主内容
Sony Walkman NWZ-E438 Battery Replacement
你所需要的
  1. Sony Walkman NWZ-E438 Battery Replacement, Disassembling Sony Walkman NWZ-E438: 步骤 1 中的图像 1,1
    • Unscrew the two screws on the back of the device using a Phillips PH000 screwdriver.
    • Keep the Phillips PH000 screwdriver aside for further steps in the guide. It will be the only screwdriver needed for this replacement.
  2. Sony Walkman NWZ-E438 Battery Replacement: 步骤 2 中的图像 1,1
    • Use a small prying tool to carefully pry open the back of the device.
  3. Sony Walkman NWZ-E438 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Peel back the black tape from the device to the battery from the side of the device.
  4. Sony Walkman NWZ-E438 Battery Replacement: 步骤 4 中的图像 1,1
    • Using a small, plastic prying tool slowly lift the battery around all edges.
    • Careful of wires connecting the battery to the device.
  5. Sony Walkman NWZ-E438 Battery Replacement: 步骤 5 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Remove the yellow film covering the circuit board with pointed precision tweezers.
  6. Sony Walkman NWZ-E438 Battery Replacement: 步骤 6 中的图像 1,2 Sony Walkman NWZ-E438 Battery Replacement: 步骤 6 中的图像 2,2
    • Using tweezers, unplug the gold band connecting the device and circuit board.
  7. Sony Walkman NWZ-E438 Battery Replacement: 步骤 7 中的图像 1,2 Sony Walkman NWZ-E438 Battery Replacement: 步骤 7 中的图像 2,2
    • Using pointed precision tweezers, unplug the wires connecting the battery and chip from the chip.
  8. Sony Walkman NWZ-E438 Battery Replacement: 步骤 8 中的图像 1,1
    • Remove battery.
结论
另外一个人完成了本指南。
一条评论
Do you have a link to purchase a replacement battery? Thanks!
jacob goff - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 39
总计 6,485
