跳转到主内容
Sony WH-CH700N Headphone Pad Cover Replacement
你所需要的
  1. Sony WH-CH700N Headphone Pad Cover Replacement, Headphone Pad Cover: 步骤 1 中的图像 1,1
    • Identify the free edge of the ear pad.
  2. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 2 中的图像 1,3 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 2 中的图像 2,3 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 2 中的图像 3,3
    • Gently pull the free edge up.
    • Slight pressure is needed, but there is no glue.
    • Fully remove the ear pad.
    • If yours are more deteriorated, make sure to remove all excess material.
  3. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 3 中的图像 1,1
    • Repeat with the other side.
  4. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    Microfiber Cleaning Cloths
    $3.99
    购买
    • Gently wipe the exposed surface with an alcohol swab or microfiber cloth.
    • Do not scrub hard in order to avoid damaging the headphones.
  5. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 5 中的图像 1,1
    • Identify the wider part of the headphone pad.
  6. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 6 中的图像 1,3 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 6 中的图像 2,3 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 6 中的图像 3,3
    • Find the lip of the leather replacement pad.
    • Line up the new ear pad with one side of the exposed headphones, wider end towards the top.
    • Gently stretch one end of the ear pad over one end of the headphone.
    • You can anchor on the top of the ear pad by tilting the headphone out at an angle.
  7. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 7 中的图像 1,3 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 7 中的图像 2,3 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 7 中的图像 3,3
    • Work your way around the ear pad, pulling the leather over the lip.
    • Pull from the inside out so that the leather catches on the lip.
    • You can use your whole hand as a grip to make sure that the leather does not slip off.
  8. Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 8 中的图像 1,2 Sony WH-CH700N Headphone Pad Cover Replacement: 步骤 8 中的图像 2,2
    • Repeat on the other side of the headphones.
终点
3等其他人完成本指南。
Jackson Inagi
于01/30/23注册
193 声望
撰写一个指南
团队
Cal Poly, Team 2-1, Johann Winter 2023 Cal Poly, Team 2-1, Johann Winter 2023 的会员
CPSU-JOHANN-W23S2G1
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 31
过去 30 天: 151
总计 1,614
