跳转到主内容
Sony Vaio VPCW21FX Headphone Jack Replacement
你所需要的
  1. Sony Vaio VPCW21FX Headphone Jack Replacement, Battery: 步骤 1 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement, Battery: 步骤 1 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement, Battery: 步骤 1 中的图像 3,3
    • Be sure to disconnect the device charger and power down the device before beginning.
    • Turn the device over onto its back, where the battery is at the top of the device. Slide the "lock" switch to the right.
  2. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 2 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 2 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 2 中的图像 3,3
    • Slide the "release" switch to the left and gently lift the battery up to remove it.
    • Completely remove the battery from the device.
  3. Sony Vaio VPCW21FX Headphone Jack Replacement, Headphone Jack: 步骤 3 中的图像 1,2 Sony Vaio VPCW21FX Headphone Jack Replacement, Headphone Jack: 步骤 3 中的图像 2,2
    • Place the laptop upside down with the bottom panel facing upwards.
    • Locate the screw that holds the small panel covering your laptop's Ram. This panel should be in the dead center of your laptop.
    • Unscrew the screw and remove the panel.
  4. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Before you move away from where your RAM is located, be sure to unplug the wire labeled To MB. If you do not unplug this, the back panel you are trying to remove will not come off.
  5. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 5 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 5 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 5 中的图像 3,3
    • Next, locate the panel covering your laptop's hard drive. This panel should be located on the lower right hand side of your laptop.
    • Unscrew the cover on the hard drive.
    • Remove the hard drive cover.
  6. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 6 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 6 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 6 中的图像 3,3
    • Remove screws.
    • Remove screws and remove panel.
  7. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 7 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 7 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 7 中的图像 3,3
    • Remove the hard drive by gently pressing down on it and sliding it to the right.
    • Remember to have a clean work space to place the parts you take off your laptop. It'd be embarrassing to forget to reassemble a part or have a screw or two left over.
  8. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 8 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 8 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 8 中的图像 3,3
    • Remove the screws holding the rest of the outside panel down.
    • Gently lift the panel up to remove it once all the screws have been removed.
  9. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 9 中的图像 1,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 9 中的图像 2,3 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 9 中的图像 3,3
    • Once the back panel has been removed, set the rest of your laptop to the side and place the panel you just removed in front of you.
    • Locate the headphone jack, which will be in the top right hand corner of the panel. The headphone jack board is a bright green, you can't miss it.
  10. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 10 中的图像 1,2 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 10 中的图像 2,2
    • Remove the screws holding the headphone jack board down.
  11. Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 11 中的图像 1,2 Sony Vaio VPCW21FX Headphone Jack Replacement: 步骤 11 中的图像 2,2
    • Gently pull the board to remove it.
结论
Rebecca
于10/10/16注册
324 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 2,810
