跳转到主内容
Sony Vaio VPCW211AX Keyboard Replacement
你所需要的
  1. Sony Vaio VPCW211AX Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Start with the laptop face up on a flat surface.
  2. Sony Vaio VPCW211AX Keyboard Replacement: 步骤 2 中的图像 1,1
    • Open the laptop with the keyboard facing you.
  3. Sony Vaio VPCW211AX Keyboard Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCW211AX Keyboard Replacement: 步骤 3 中的图像 2,2
    • Use a plastic opening tool to pry up the keyboard. Start at the end closest to the screen.
    • Be careful around the edges; work your way around the keyboard until all of it is detached.
    • There will be a ribbon cable attached to the bottom of the keyboard. Be sure not to rip the cable when lifting the keyboard from the laptop frame.
  4. Sony Vaio VPCW211AX Keyboard Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCW211AX Keyboard Replacement: 步骤 4 中的图像 2,2
    • Carefully detach the ribbon from the base of the computer with your hands.
    • Remove the keyboard.
结论
另外一个人完成了本指南。
Giselle Dougan
于01/31/18注册
760 声望
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 531
