跳转到主内容
Sony Vaio VPCEL17FX Hard Drive Replacement
你所需要的
  1. Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 2,3 Sony Vaio VPCEL17FX Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 3,3
    • First, locate the hard drive slot on the under side of the laptop.
    • Unscrew the screws using your Phillips #00 screwdriver.
    • Set the two screws aside so you can screw them in later on when you're finished.
    • This should reveal a small metallic place holder that your hard drive belongs.
  2. Sony Vaio VPCEL17FX Hard Drive Replacement: 步骤 2 中的图像 1,2 Sony Vaio VPCEL17FX Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Unscrew the 4 hard drive bracket screws.
    • Once the screw is undone you can pull the place holder back to find the slot where the actual hard drive belongs.
    • Remember to set aside the screw so you can correctly install the hard drive.
结论
The installation/replacement is a very easy task that can be done by anyone.
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 11
总计 615
