跳转到主内容
Sony Vaio VPCEG37FM Battery Replacement
  1. Sony Vaio VPCEG37FM Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Unlock the battery by sliding the lock upwards.
  2. Sony Vaio VPCEG37FM Battery Replacement: 步骤 2 中的图像 1,2 Sony Vaio VPCEG37FM Battery Replacement: 步骤 2 中的图像 2,2
    • Slide the release upwards and lift out the battery to remove.
    • Once battery is removed, long press the Power button for 30-60s and discharge any remaining power inside of the computer.
    • Put on the ESD bracelet, making sure the metal circle is touching your skin. Remove the alligator clip from the other end of the bracelet and insert the jack into the ground plug of an active electrical outlet. (the round hole). Do not move forward until you are grounded.
结论
Morgynn Richlark
于09/25/17注册
115 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 19
总计 1,445
