跳转到主内容
Sony Vaio VPCEG26FX RAM Replacement
你所需要的
  1. Sony Vaio VPCEG26FX  RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop so the bottom is facing up with the model number visible.
  2. Sony Vaio VPCEG26FX  RAM Replacement: 步骤 2 中的图像 1,2 Sony Vaio VPCEG26FX  RAM Replacement: 步骤 2 中的图像 2,2
    • Slide the lock switch down until you hear a click to unlock the battery.
  3. Sony Vaio VPCEG26FX  RAM Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCEG26FX  RAM Replacement: 步骤 3 中的图像 2,2
    • Slide the release slider up and simultaneously push the battery upwards away from the device until it falls out of place.
  4. Sony Vaio VPCEG26FX  RAM Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCEG26FX  RAM Replacement: 步骤 4 中的图像 2,2
    • Remove the battery from the battery compartment.
  5. Sony Vaio VPCEG26FX  RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • After you remove the battery, there is a small rectangular panel underneath where the battery was housed.
  6. Sony Vaio VPCEG26FX  RAM Replacement: 步骤 6 中的图像 1,1
    • Remove the single screw holding the panel in place using the JIS #0 screwdriver.
  7. Sony Vaio VPCEG26FX  RAM Replacement: 步骤 7 中的图像 1,3 Sony Vaio VPCEG26FX  RAM Replacement: 步骤 7 中的图像 2,3 Sony Vaio VPCEG26FX  RAM Replacement: 步骤 7 中的图像 3,3
    • Remove the green circuit board by dislodging the circuit it is attached to.
    • Unhook it and remove it from the device.
结论
Sara Alfaro
于03/08/19注册
546 声望
创作了5篇指南
团队
UMass Dartmouth, Team S1-G4, Botvin Spring 2019 UMass Dartmouth, Team S1-G4, Botvin Spring 2019 的会员
UMASSD-BOTVIN-S19S1G4
4 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 11
总计 896
