跳转到主内容
Sony Vaio VPCEB11FM Wifi Card Replacement
你所需要的
  1. Sony Vaio VPCEB11FM Wifi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 2 中的图像 1,1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Wifi Card Replacement, RAM: 步骤 4 中的图像 1,2 Sony Vaio VPCEB11FM Wifi Card Replacement, RAM: 步骤 4 中的图像 2,2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 5 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 5 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 5 中的图像 3,3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
  6. Sony Vaio VPCEB11FM Wifi Card Replacement, Hard Drive: 步骤 6 中的图像 1,2 Sony Vaio VPCEB11FM Wifi Card Replacement, Hard Drive: 步骤 6 中的图像 2,2
    • Using the Phillips #01 Screwdriver, remove the two 7mm screws.
  7. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 7 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 7 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 7 中的图像 3,3
    • Use your fingers to pry the cover upward.
    • Unscrew the two 7mm screws.
    • Pull the plastic tab in the direction of the arrow to take out.
  8. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 8 中的图像 1,2 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 8 中的图像 2,2
    • Lift plug side first.
    • Remove all the way.
  9. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 9 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 9 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 9 中的图像 3,3
    • Skip to next step if accessing other components.
    • Remove the 3mm screws with the Phillips #1 Screwdriver from hard drive bracket.
  10. Sony Vaio VPCEB11FM Wifi Card Replacement, DVD Drive: 步骤 10 中的图像 1,2 Sony Vaio VPCEB11FM Wifi Card Replacement, DVD Drive: 步骤 10 中的图像 2,2
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  11. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 11 中的图像 1,1
    • Grasp the DVD drive's face plate with your fingers and pull out.
  12. Sony Vaio VPCEB11FM Wifi Card Replacement, Cooling Fan: 步骤 12 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement, Cooling Fan: 步骤 12 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement, Cooling Fan: 步骤 12 中的图像 3,3
    • Remove ten 7mm screws with the Phillips #1 Screwdriver.
    • Remove two 8mm screws with the Phillips #1 Screwdriver.
    • Remove two 3mm screws with the Phillips #1 Screwdriver.
  13. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 13 中的图像 1,2 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 13 中的图像 2,2
    • Remove SD card slot block by pushing it in until it releases.
    • Once released pull out to remove.
  14. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 14 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 14 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 14 中的图像 3,3
    • To take off the cover plate, start by finding a loose corner to begin prying it open.
    • Work the tool around the sides to release the cover. You may need a second tool to help keep your loose corner open.
    • Lift cover away.
    • NOTE: If you are attempting to access other components, skip 2 steps.
  15. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 15 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 15 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 15 中的图像 3,3
    • Remove the plug shown using a pry tool.
    • Remove seven 5mm screws with the Phillips #01 Screwdriver.
  16. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 16 中的图像 1,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 16 中的图像 2,3 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 16 中的图像 3,3
    • To break the thermal paste, apply gentle constant upward force until it comes free.
    • Remove four 3.5mm screws with the Phillips #000 Screwdriver to access cooling fan.
  17. Sony Vaio VPCEB11FM Wifi Card Replacement, Wifi Card: 步骤 17 中的图像 1,1
    • Continuing from Step 3.
  18. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 18 中的图像 1,1
    • Carefully remove the antenna plugs.
  19. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 19 中的图像 1,2 Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 19 中的图像 2,2
    • Remove the 3mm screw with the Phillips #01 Screwdriver
  20. Sony Vaio VPCEB11FM Wifi Card Replacement: 步骤 20 中的图像 1,1
    • Remove the Wifi Card.
结论
另外一个人完成了本指南。
Maxine Filcher
于01/30/17注册
1,135 声望
创作了8篇指南
团队
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 的会员
UWT-ROSE-W17S1G5
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 26
总计 1,671
