跳转到主内容
加入维修社区 - 创建账户
Sony Vaio VPCEB11FM RAM Replacement
你所需要的
  1. Sony Vaio VPCEB11FM RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM RAM Replacement: 步骤 2 中的图像 1,1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM RAM Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM RAM Replacement, RAM: 步骤 4 中的图像 1,2 Sony Vaio VPCEB11FM RAM Replacement, RAM: 步骤 4 中的图像 2,2
    • Unscrew the RAM cover plate using the Phillips #1 Screwdriver.
    • Once the cover has been loosened, pry the cover with your finger for it to come off.
  5. Sony Vaio VPCEB11FM RAM Replacement: 步骤 5 中的图像 1,3 Sony Vaio VPCEB11FM RAM Replacement: 步骤 5 中的图像 2,3 Sony Vaio VPCEB11FM RAM Replacement: 步骤 5 中的图像 3,3
    • Use your fingers to gently pull the white plastic strip outward on both sides.
    • Once you pull the strip, the strip of RAM will loosen up. Once loose the strip of RAM should lift out.
    • Once done with the top strip of RAM continue for all continuous strips.
结论
另外一个人完成了本指南。
Maxine Filcher
于01/30/17注册
1,153 声望
创作了8篇指南
团队
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 的会员
UWT-ROSE-W17S1G5
4 名成员
创作了16篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 30
总计 2,000
