跳转到主内容
Sony Vaio VPCEB11FM Keyboard Replacement
你所需要的
  1. Sony Vaio VPCEB11FM Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Power down and disconnect the laptop from power supply.
    • Using your fingers, unlock the tab by pushing on the slide.
  2. Sony Vaio VPCEB11FM Keyboard Replacement: 步骤 2 中的图像 1,1
    • While holding the release slide, use your thumb to lift the lip of the battery to pull it out.
  3. Sony Vaio VPCEB11FM Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out.
  4. Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: 步骤 4 中的图像 1,2 Sony Vaio VPCEB11FM Keyboard Replacement, DVD Drive: 步骤 4 中的图像 2,2
    • Remove the 7mm screws with the Phillips #1 Screwdriver.
  5. Sony Vaio VPCEB11FM Keyboard Replacement: 步骤 5 中的图像 1,1
    • Grasp the DVD drive's face plate with your fingers and pull out.
  6. Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: 步骤 6 中的图像 1,3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: 步骤 6 中的图像 2,3 Sony Vaio VPCEB11FM Keyboard Replacement, Keyboard: 步骤 6 中的图像 3,3
    • Within the DVD drive compartment, press on the hole to push the keyboard out of its placement.
    • The keyboard may need to be loosened on its edges with a plastic spudger.
  7. Sony Vaio VPCEB11FM Keyboard Replacement: 步骤 7 中的图像 1,3 Sony Vaio VPCEB11FM Keyboard Replacement: 步骤 7 中的图像 2,3 Sony Vaio VPCEB11FM Keyboard Replacement: 步骤 7 中的图像 3,3
    • Carefully pull the keyboard back to expose ribbon connector.
    • Using a spudger, or your finger tips, carefully slide the the ribbon keeper open.
结论
另外一个人完成了本指南。
Maxine Filcher
于01/30/17注册
1,135 声望
创作了8篇指南
团队
UW Tacoma, Team 1-5, Rose Winter 2017 UW Tacoma, Team 1-5, Rose Winter 2017 的会员
UWT-ROSE-W17S1G5
4 名成员
创作了16篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 16
总计 1,941
