跳转到主内容
Sony Vaio VPCCW17FX RAM Replacement
你所需要的
  1. Sony Vaio VPCCW17FX RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX RAM Replacement: 步骤 2 中的图像 1,1
    • Slide both latches to the center of the laptop in order to release the battery.
  3. Sony Vaio VPCCW17FX RAM Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCCW17FX RAM Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX RAM Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCCW17FX RAM Replacement: 步骤 4 中的图像 2,2
    • Using a Phillips #0 screwdriver, remove the one screw (Length: 7.7 mm) that is covering the RAM.
  5. Sony Vaio VPCCW17FX RAM Replacement: 步骤 5 中的图像 1,1
    • Lift the black plastic cover to assess the RAM.
  6. Sony Vaio VPCCW17FX RAM Replacement: 步骤 6 中的图像 1,3 Sony Vaio VPCCW17FX RAM Replacement: 步骤 6 中的图像 2,3 Sony Vaio VPCCW17FX RAM Replacement: 步骤 6 中的图像 3,3
    • Apply light, outward pressure to the locks on both sides of the RAM.
    • Rotate the RAM up and slowly pull towards you to remove it.
  7. Sony Vaio VPCCW17FX RAM Replacement: 步骤 7 中的图像 1,3 Sony Vaio VPCCW17FX RAM Replacement: 步骤 7 中的图像 2,3 Sony Vaio VPCCW17FX RAM Replacement: 步骤 7 中的图像 3,3
    • In order to remove the secondary RAM, use the same outward pressure on the locks.
    • Lift and slide out the RAM to remove it from the slot.
结论
Mia Martinez
于03/30/17注册
101 声望
撰写一个指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 1,157
