跳转到主内容
Sony Vaio VPCCW17FX LCD Screen Replacement
你所需要的
  1. Sony Vaio VPCCW17FX LCD Screen Replacement, LCD Screen: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 2 中的图像 1,1
    • Slide both latches towards the center of the battery to release.
  3. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 3 中的图像 2,2
    • Use your fingernail or a plastic tool to lift the battery. Rotate the battery up and away to remove from the laptop.
  4. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 4 中的图像 2,2
    • Remove the rubber pads on all four corners of the screen bezel using the spudger.
    • Remove the four screws (Length: 7.7 mm) using the Phillips #0 screwdriver.
  5. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 5 中的图像 1,1
    • Remove the screen's plastic bezel.
    • You need to use slight pressure to release the clips.
  6. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 6 中的图像 1,2 Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 6 中的图像 2,2
    • Remove all four screws (Length: 7.7 mm) using a Phillips #0 screwdriver. Make sure to hold the screen while removing the screws so it doesn't fall.
    • Using your thumb, carefully lower the glass and place it on the keyboard.
    • Do this slowly to avoid damaging the screen.
  7. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 7 中的图像 1,2 Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 7 中的图像 2,2
    • Pull off the tape and disconnect the display cable connector by gently sliding up to remove it from its socket.
  8. Sony Vaio VPCCW17FX LCD Screen Replacement: 步骤 8 中的图像 1,1
    • The screen can now be removed.
结论
另外一个人完成了本指南。
Seowon Song
于03/20/17注册
113 声望
撰写一个指南
团队
Texas Tech, Team S8-G5, Bennett Spring 2017 Texas Tech, Team S8-G5, Bennett Spring 2017 的会员
TTU-BENNETT-S17S8G5
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 20
总计 1,123
