跳转到主内容
Sony Vaio VPCCW17FX Back Case
你所需要的
  1. Sony Vaio VPCCW17FX Back Case, Back case: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown.
  2. Sony Vaio VPCCW17FX Back Case: 步骤 2 中的图像 1,3 Sony Vaio VPCCW17FX Back Case: 步骤 2 中的图像 2,3 Sony Vaio VPCCW17FX Back Case: 步骤 2 中的图像 3,3
    • Remove the battery by pinching the two lock tabs towards the center.
    • Next, lift up on the battery to remove it.
  3. Sony Vaio VPCCW17FX Back Case: 步骤 3 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the twenty-two 5.6 mm screws from the back of the laptop.
    • Be sure to remove all screws, including those that are typically covered by the battery.
  4. Sony Vaio VPCCW17FX Back Case: 步骤 4 中的图像 1,3 Sony Vaio VPCCW17FX Back Case: 步骤 4 中的图像 2,3 Sony Vaio VPCCW17FX Back Case: 步骤 4 中的图像 3,3
    • Now, remove the small covers from the back of the case.
    • Using a Phillips #00 screwdriver, unscrew the three 5.6 mm screws from the covers (one screw on the RAM cover [middle] and two screws on the Hard Drive cover [bottom right]).
    • Then, lift up on and remove these covers as shown in the third image.
  5. Sony Vaio VPCCW17FX Back Case: 步骤 5 中的图像 1,3 Sony Vaio VPCCW17FX Back Case: 步骤 5 中的图像 2,3 Sony Vaio VPCCW17FX Back Case: 步骤 5 中的图像 3,3
    • Remove the hard drive.
    • Using a Phillips #00 screwdriver, unscrew the two remaining 4.9 mm screws holding the hard drive into place.
    • Next, lift up and pull outwards to release the hard drive from its socket.
  6. Sony Vaio VPCCW17FX Back Case: 步骤 6 中的图像 1,1
    • Using your fingers, grasp the black tab and lightly pull up on the ribbon cable to detach it from the motherboard.
  7. Sony Vaio VPCCW17FX Back Case: 步骤 7 中的图像 1,1
    • After proper removal of all necessary screws, gently lift up on the back case to remove it.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 23
总计 1,008
