跳转到主内容
Sony Vaio VPCCB290X Keyboard Replacement
你所需要的
  1. Sony Vaio VPCCB290X Keyboard Replacement, Keyboard: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Anti-Static Wrist Strap
    $7.95
    购买
    • Attach an anti-static wrist strap to a piece of metal to prevent possible short circuiting.
    • Use a spudger to press in the black clips that lock the keyboard in place.
    • As you press in the black clips, remove the screws near the motherboard using the screwdriver.
    • Do not remove the motherboard.
  2. Sony Vaio VPCCB290X Keyboard Replacement: 步骤 2 中的图像 1,1
    • Using the metal spudger, pick a corner and carefully begin to pop off the keyboard.
    • It is normal to hear a soft clicking sound as the keyboard releases from the device.
  3. Sony Vaio VPCCB290X Keyboard Replacement: 步骤 3 中的图像 1,1
    • Two cables are attached to two white inserts to keep the keyboard anchored in place once the clips have been removed, and to keep the keyboard attached to the motherboard.
    • Unplug the thin cable by just simply pulling the cable straight out of the connector.
    • Leave the thicker white cable alone.
  4. Sony Vaio VPCCB290X Keyboard Replacement: 步骤 4 中的图像 1,2 Sony Vaio VPCCB290X Keyboard Replacement: 步骤 4 中的图像 2,2
    • To fully release the old keyboard, lift the black wedge clip by using the spudger tool to press down on the clip and release the wider cable.
终点
Eric Martinez
于02/14/17注册
637 声望
创作了6篇指南
团队
USF Tampa, Team 20-5, Remmell Spring 2017 USF Tampa, Team 20-5, Remmell Spring 2017 的会员
USFT-REMMELL-S17S20G5
3 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 11
总计 599
