跳转到主内容
Sony Vaio VPC-Y2190X Hard Drive Replacement
你所需要的
  1. Sony Vaio VPC-Y2190X Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip your laptop so that the bottom is facing up.
  2. Sony Vaio VPC-Y2190X Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the “Lock” switch to the right.
    • Slide and hold the “Release” switch to the left.
  3. Sony Vaio VPC-Y2190X Hard Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio VPC-Y2190X Hard Drive Replacement: 步骤 3 中的图像 2,2
    • While holding the “Release” switch, lift the lip of the battery.
    • Lift the battery up and out of the laptop.
  4. Sony Vaio VPC-Y2190X Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Using a #0PH screwdriver, unscrew the three 4.80mm screws on the back of the device.
    • The screws are held into the panel by washers, they will not fall out once unscrewed.
  5. Sony Vaio VPC-Y2190X Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Remove the panel.
    • Use the #0PH screwdriver to remove the four 3.61mm screws.
  6. Sony Vaio VPC-Y2190X Hard Drive Replacement: 步骤 6 中的图像 1,2 Sony Vaio VPC-Y2190X Hard Drive Replacement: 步骤 6 中的图像 2,2
    • Carefully lift the hard drive.
    • Remove the hard drive by pulling it to the left.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 350
