跳转到主内容
Sony Vaio VGN-TXN25N Display Screen Replacement
你所需要的
  1. Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: 步骤 1 中的图像 1,2 Sony Vaio VGN-TXN25N Display Screen Replacement, Display Screen: 步骤 1 中的图像 2,2
    • Place the computer on a flat surface with the top facing up.
    • Open the screen.
  2. Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 2 中的图像 1,3 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 2 中的图像 2,3 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 2 中的图像 3,3
    • Locate the rubber screw caps at the two bottom corners of the screen.
    • Use your finger to remove the rubber screw caps.
  3. Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 3 中的图像 2,2
    • Locate the two screws, one on each bottom corner.
    • Unscrew the screws with a Phillips head size #0 screwdriver.
    • Keep track of the screws. They are small and easy to misplace.
  4. Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 4 中的图像 1,3 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 4 中的图像 2,3 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 4 中的图像 3,3
    • Use a plastic opening tool to gently lift the plastic casing that borders the screen.
    • Pop off the casing by working the tool around the outside of it.
    • Wiggling the tool may be required. The casing could be fitted snugly.
  5. Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 5 中的图像 1,3 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 5 中的图像 2,3 Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 5 中的图像 3,3
    • Carefully flip down the screen so it rests on the keyboard.
    • Locate the wire connector on the back of the screen and use a plastic opening tool to gently loosen the wire connection.
  6. Sony Vaio VGN-TXN25N Display Screen Replacement: 步骤 6 中的图像 1,1
    • Remove the screen.
结论
另外一个人完成了本指南。
Andrew Ricker
于04/04/12注册
71 声望
撰写一个指南
团队
Cal Poly, Team 5-3, Forte Spring 2012 Cal Poly, Team 5-3, Forte Spring 2012 的会员
CPSU-FORTE-S12S5G3
5 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 13
总计 3,595
