简介
This is a detialed repair manual to show how to properly remove and install speakers in the Sony Vaio VGN-SZ120P.
Hazards
Keep out of reach of children and pets.
DO NOT attempt to teardown or repair your device under the influence of drugs or alcohol.
DO NOT ingest any parts of the system.
Use the correct tools as stated in the tools section.
DO NOT touch any gold connectors on interior or exterior of the system.
Make sure system is unplugged before performing any maintenance on the system.
你所需要的
Set the computer display-side down.
Unlock the battery by sliding the port-side latch to the 'unlock' position.
Turn the laptop upside down.
Remove the three screws from the front mouse panel located on the bottom of the laptop.
Remove the four screws from the underside of the computer. These screws are located underneath where the battery sits and secure the top keyboard panel.
To remove the panel below the screen, press up on the two tabs holding the panel in and lift up. The panel should pop off.
Before proceeding, remove all black tape holding down wires and other cabling.
另外一个人完成了本指南。
