跳转到主内容
Sony Vaio VGN-SR140E RAM Replacement
你所需要的
  1. Sony Vaio VGN-SR140E RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E RAM Replacement: 步骤 2 中的图像 1,1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E RAM Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-SR140E RAM Replacement: 步骤 3 中的图像 2,2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E RAM Replacement, RAM: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screwdriver, remove both screws. The screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E RAM Replacement: 步骤 5 中的图像 1,2 Sony Vaio VGN-SR140E RAM Replacement: 步骤 5 中的图像 2,2
    • Lift the thin black plastic cover to access the RAM.
  6. Sony Vaio VGN-SR140E RAM Replacement: 步骤 6 中的图像 1,2 Sony Vaio VGN-SR140E RAM Replacement: 步骤 6 中的图像 2,2
    • Apply light outward pressure to the locks on either side of the RAM. Rotate the RAM up slightly. Pull the RAM toward you to remove it.
  7. Sony Vaio VGN-SR140E RAM Replacement: 步骤 7 中的图像 1,3 Sony Vaio VGN-SR140E RAM Replacement: 步骤 7 中的图像 2,3 Sony Vaio VGN-SR140E RAM Replacement: 步骤 7 中的图像 3,3
    • Using the same light outward pressure on the locks, lift the secondary RAM up and slide it away from you to remove it from its slot.
结论
Jeremy
于03/18/15注册
722 声望
创作了4篇指南
团队
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 13
总计 477
