跳转到主内容
Sony Vaio VGN-SR140E Hard Drive Replacement
你所需要的
  1. Sony Vaio VGN-SR140E Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
  4. Sony Vaio VGN-SR140E Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,1
    • Using a Phillips #1 screw driver, loosen both screws holding the cover in place. These screws are secured to the cover with retaining clips.
  5. Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Lift the cover with a fingernail or plastic opening tool from the side where the screws are present and lift it off to the left.
  6. Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 6 中的图像 1,1
    • The hard drive is covered by a thin, black, plastic flap. Gently lift the hard drive up and to the right.
    • Be careful not to damage the ribbon cable during this step.
  7. Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 7 中的图像 1,2 Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 7 中的图像 2,2
    • Use the spudger or a fingernail to carefully release the lock securing the ribbon cable to the motherboard.
  8. Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 8 中的图像 1,2 Sony Vaio VGN-SR140E Hard Drive Replacement: 步骤 8 中的图像 2,2
    • Grasp the ribbon cable carefully near the connector end. Remove it by pulling the cable away from the connector on the motherboard at a slightly upward angle.
结论
另外一个人完成了本指南。
Jeremy
于03/18/15注册
722 声望
创作了4篇指南
团队
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 14
总计 931
