跳转到主内容
Sony Vaio VGN-SR140E Battery Replacement
你所需要的
  1. Sony Vaio VGN-SR140E Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over and orient it as shown in the figure.
  2. Sony Vaio VGN-SR140E Battery Replacement: 步骤 2 中的图像 1,1
    • Slide the lock latch to the right to release the battery lock.
    • Slide and hold the release latch to the left.
  3. Sony Vaio VGN-SR140E Battery Replacement: 步骤 3 中的图像 1,2 Sony Vaio VGN-SR140E Battery Replacement: 步骤 3 中的图像 2,2
    • Use a fingernail or plastic opening tool lift the battery while holding the release latch.Rotate the battery up and away from you to remove it from the laptop.
结论
To reinstall the battery, follow these steps in reverse order
William Thomas
于03/18/15注册
125 声望
撰写一个指南
团队
Michigan Tech, Team 1-6, Lauer Spring 2015 Michigan Tech, Team 1-6, Lauer Spring 2015 的会员
MTU-LAUER-S15S1G6
2 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 15
总计 1,096
