跳转到主内容
修复你的物品
维修的权力
商店
简介
How to get out the RAM of your Sony Vaio VGN-S260
配件
没有特定配件。
  1. Flip the laptop over so the Vaio logo is facing down. Locate the battery at the top and Find the release and unlock slides on the battery. Slide the unlock tab to the unlock position.
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. With the tabs still in the unlock position, slide the battery away from the main case. With the tabs still in the unlock position, slide the battery away from the main case.
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. 跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
    跳过升级
    通过使用多合一工具包维修可以节省成本。
    购买 iPhone 维修工具套装
  4. With the laptop still flipped over with the Vaio logo facedown, locate the screws for the RAM Remove the screws
    • With the laptop still flipped over with the Vaio logo facedown, locate the screws for the RAM
    • Remove the screws
  5. Lift off the unscrewed cover
    • Lift off the unscrewed cover
    • Locate the RAM
  6. Locate tabs next to RAM Pull the 2 tabs away from the RAM The RAM should pop up.
    • Locate tabs next to RAM
    • Pull the 2 tabs away from the RAM
    • The RAM should pop up.
  7. Gently slide the RAM up and out
    • Gently slide the RAM up and out
结论
Jeffrey Bryan
于2010年04月20日注册
552 信誉积分
创作了11篇指南
团队
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G4
4 名成员
创作了11篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 3,499
