跳转到主内容
Sony Vaio VGN-S260 Motherboard Replacement
你所需要的
  1. Sony Vaio VGN-S260 Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Sony Vaio VGN-S260 Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Sony Vaio VGN-S260 Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 2 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 2 中的图像 2,2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Motherboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 4 中的图像 1,1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 5 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 5 中的图像 2,2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 6 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Lift up lever underneath the ribbon to detach the keyboard.
  7. Sony Vaio VGN-S260 Motherboard Replacement, Upper Casing: 步骤 7 中的图像 1,1
    • Remove memory/wireless compartment cover.
  8. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 8 中的图像 1,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 8 中的图像 2,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 8 中的图像 3,3
    • Flip so the Vaio Logo is face down.
    • Locate and remove a total of 8 screws on the bottom.
  9. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 9 中的图像 1,1
    • Find and remove 5 screws (they all have arrows next to them) from cover.
  10. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 10 中的图像 1,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 10 中的图像 2,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 10 中的图像 3,3
    • Flip the laptop over so the Vaio logo is face up.
    • Use the spudger to pop up the upper casing.
    • Do not lift too much as the upper casing is attached to wires underneath.
    • Remove the wires that are attaching the upper casing to the motherboard.
  11. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Remove the upper casing.
  12. Sony Vaio VGN-S260 Motherboard Replacement, Power Adapter: 步骤 12 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement, Power Adapter: 步骤 12 中的图像 2,2
    • Locate the yellow power adapter.
    • Follow its wire to white logic board connector.
    • Pull out the wire from white logic board connector.
  13. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 13 中的图像 1,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 13 中的图像 2,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 13 中的图像 3,3
    • Locate the screws on the fan filter casing.
    • Remove these screws.
  14. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 14 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 14 中的图像 2,2
    • Remove the screw next to the yellow power adapter.
    • Lift out power adapter and fan filter.
  15. Sony Vaio VGN-S260 Motherboard Replacement, Optical Drive: 步骤 15 中的图像 1,1
    • Remove the screw holding the optical drive casing to the logic board.
  16. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 16 中的图像 1,1
    • Locate ribbon connecting optical drive case to logic board.
    • Pop off the ribbon.
    • Remove the metal PC-Card cage.
  17. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 17 中的图像 1,1
    • Remove the four screws holding the optical drive to the logic board.
  18. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 18 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 18 中的图像 2,2
    • Locate brown locking tab above optical drive.
    • Lift up on brown locking tab until ribbon is loose.
    • Gently slide out and remove the optical drive from the computer.
  19. Sony Vaio VGN-S260 Motherboard Replacement, Ethernet Ports: 步骤 19 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement, Ethernet Ports: 步骤 19 中的图像 2,2
    • Remove the blue ribbon from the Ethernet Circuit Board.
  20. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 20 中的图像 1,1
    • Remove the screws near the Ethernet Port circuit board.
  21. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 21 中的图像 1,1
    • Remove the screws for the second ethernet circuit board.
  22. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 22 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 22 中的图像 2,2
    • Remove the ethernet ports.
  23. Sony Vaio VGN-S260 Motherboard Replacement, Hard Drive: 步骤 23 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement, Hard Drive: 步骤 23 中的图像 2,2
    • Remove the screws holding the hard drive casing in place.
  24. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 24 中的图像 1,1
    • Find orange ribbon that is connected to the hard drive.
    • Find the holder of the ribbon and pop the ribbon off from it.
  25. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 25 中的图像 1,1
    • Remove the casing and the orange ribbon.
  26. Sony Vaio VGN-S260 Motherboard Replacement, Motherboard: 步骤 26 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement, Motherboard: 步骤 26 中的图像 2,2
    • Remove screws on the motherboard.
  27. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 27 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 27 中的图像 2,2
    • Remove the nut using a 5mm nut driver.
    • Using a magnetic screwdriver handle will also work as well.
  28. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 28 中的图像 1,2 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 28 中的图像 2,2
    • Remove the LCD display ribbon with a nylon spudger.
    • This is difficult to remove.
  29. Sony Vaio VGN-S260 Motherboard Replacement: 步骤 29 中的图像 1,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 29 中的图像 2,3 Sony Vaio VGN-S260 Motherboard Replacement: 步骤 29 中的图像 3,3
    • Gently lift the motherboard from the laptop.
    • The motherboard will be attached to the network wireless chip, which is also attached to the base of the laptop.
    • Remove the chip by popping the tabs on the side.
    • Slide out the network card.
    • You are now free to take the motherboard away from the base.
结论
另外一个人完成了本指南。
Jeffrey Bryan
于04/20/10注册
570 声望
创作了11篇指南
团队
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G4
4 名成员
创作了30篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 7,334
