跳转到主内容
Sony Vaio VGN-S260 Keyboard Replacement
你所需要的
  1. Sony Vaio VGN-S260 Keyboard Replacement, Battery: 步骤 1 中的图像 1,3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: 步骤 1 中的图像 2,3 Sony Vaio VGN-S260 Keyboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Flip the laptop over so the Vaio logo is facing down.
    • Locate the battery at the top and Find the release and unlock slides on the battery.
    • Slide the unlock tab to the unlock position.
    • Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
  2. Sony Vaio VGN-S260 Keyboard Replacement: 步骤 2 中的图像 1,2 Sony Vaio VGN-S260 Keyboard Replacement: 步骤 2 中的图像 2,2
    • With the tabs still in the unlock position, slide the battery away from the main case.
  3. Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: 步骤 3 中的图像 1,2 Sony Vaio VGN-S260 Keyboard Replacement, Keyboard: 步骤 3 中的图像 2,2
    • Flip the computer over so the Vaio logo is facedown.
    • Unscrew the 2 screws next to the battery.
  4. Sony Vaio VGN-S260 Keyboard Replacement: 步骤 4 中的图像 1,1
    • Flip the computer over again so the Vaio logo is face up.
    • Open the lid.
  5. Sony Vaio VGN-S260 Keyboard Replacement: 步骤 5 中的图像 1,2 Sony Vaio VGN-S260 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Press down on the outer gray shell around the keyboard.
    • Use the spudger to gently lift keyboard.
    • Do not pull up the keyboard too far as it is attached to a ribbon underneath.
  6. Sony Vaio VGN-S260 Keyboard Replacement: 步骤 6 中的图像 1,2 Sony Vaio VGN-S260 Keyboard Replacement: 步骤 6 中的图像 2,2
    • Lift up lever underneath the ribbon to detach the keyboard.
结论
另外一个人完成了本指南。
Jeffrey Bryan
于04/20/10注册
570 声望
创作了11篇指南
团队
Cal Poly, Team 16-4, Maness Spring 2010 Cal Poly, Team 16-4, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G4
4 名成员
创作了30篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 5,477
