当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Flip the laptop over so the Vaio logo is facing down.
Locate the battery at the top and Find the release and unlock slides on the battery.
Slide the unlock tab to the unlock position.
Slide the release tab in the direction of the arrow, i.e. towards the unlock tab.
Press down on the outer gray shell around the keyboard.
Use the spudger to gently lift keyboard.
Do not pull up the keyboard too far as it is attached to a ribbon underneath.
Flip the laptop over so the Vaio logo is face up.
Use the spudger to pop up the upper casing.
Do not lift too much as the upper casing is attached to wires underneath.
Remove the wires that are attaching the upper casing to the motherboard.
Locate brown locking tab above optical drive.
Lift up on brown locking tab until ribbon is loose.
Gently slide out and remove the optical drive from the computer.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
