跳转到主内容
Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement
你所需要的
  1. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement, Optical Drive: 步骤 1 中的图像 1,1
    • Locate and unscrew the two highlighted 8 mm Phillips #1 screws.
    • There will be three dots next to the desired screws
  2. Sony Vaio VGN-NW240F (PCG-7184L) Optical Drive Replacement: 步骤 2 中的图像 1,1
    • Grip the cover of the optical drive and slide it out.
    • If it does not come out, do not force it. Double check to make sure the screws are entirely removed.
结论
另外一个人完成了本指南。
Kevin McGowan
于04/22/14注册
619 声望
创作了4篇指南
团队
Cal Poly, Team 9-17, Regan Spring 2014 Cal Poly, Team 9-17, Regan Spring 2014 的会员
CPSU-REGAN-S14S9G17
4 名成员
创作了18篇指南
一条评论
Has anyone found a suitable optical enclosure that would accommodate the front edge of this drive? Every enclosure I've seen so far would have the door protruding past the enclosure's opening (as opposed to sitting flush with the enclosure's opening), leaving its top edge unprotected.
Lotus Flower - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 1,745
