跳转到主内容
Sony Vaio VGN-FS640 Backplate Replacement
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Sony Vaio VGN-FS640 Backplate Replacement, Backplate: 步骤 1 中的图像 1,1
    • Turn off the laptop and disconnect any charging cables.
    • Flip the laptop over so that the Service Tag is shown at the top left corner.
  2. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 2 中的图像 1,1
    • Remove the highlighted screws from the back of the laptop with a Phillips #0 Screwdriver.
  3. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 3 中的图像 1,1
    • Remove the highlighted screws from the panels in the bottom right-hand corner of the laptop using the Phillips #0 Screwdriver.
  4. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 4 中的图像 1,1
    • Remove the two panels in the bottom right-hand corner by sliding in the direction of the arrows imprinted on the panels.
  5. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 5 中的图像 1,1
    • Remove the highlighted screws underneath the removed panels using the Phillips #0 Screwdriver.
  6. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 6 中的图像 1,1
    • Carefully remove the hard drive from the panel in the bottom right-hand corner of the laptop.
  7. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 7 中的图像 1,1
    • Locate the battery, located on the top side of the laptop to the right of the Service Tag .
    • Remove the battery by pressing inwards on the tabs on either side of the battery.
  8. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 8 中的图像 1,1
    • Remove cover in the top left side of the laptop next to the battery by pulling it outwards.
  9. Sony Vaio VGN-FS640 Backplate Replacement: 步骤 9 中的图像 1,1
    • Remove the backplate of the laptop by pulling it away from the laptop.
结论
另外一个人完成了本指南。
shamaz
于03/12/14注册
125 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 UMass Dartmouth, Team 2-6, Vijaybhaskar Spring 2014 的会员
UMASSD-VIJAYBHASKAR-S14S2G6
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 8
总计 365
