跳转到主内容
Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement
你所需要的
  1. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Locate the hard drive.
  2. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 2 中的图像 1,2 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Locate the 13mm screws for the hard drive and use the JIS 0 screwdriver to unscrew.
  3. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 3 中的图像 1,3 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 3 中的图像 2,3 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 3 中的图像 3,3
    • Gently lift the hard drive upwards.
    • Ensure you have a gentle hold on the hard drive cable.
    • Gently pull the cable from the base where the cable header meets the hard drive.
    • To ensure no damage is done on the cable header, pull the header gently from both sides at the same time or gently from the center.
  4. Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 4 中的图像 1,2 Sony Vaio Tap 21 SVT212A11L Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Locate the screws.
    • Using the JIS 0 screwdriver, unscrew the 4mm screws.
    • Gently lift the frame after screws have been taken out.
结论
2等其他人完成本指南。
Mauricio Retana
于10/02/17注册
763 声望
创作了6篇指南
团队
Cal Poly, Team S4-G4, Livingston Fall 2017 Cal Poly, Team S4-G4, Livingston Fall 2017 的会员
CPSU-LIVINGSTON-F17S4G4
4 名成员
创作了12篇指南
12条评论
Is that a M.2 SSD Slot on the motherboard?
tedsoldier - 回复
Nope, that’s an mPCIE/mSATA slot, not an m.2 slot. Look at the retention screw position: m.2 uses a centre screw, mPCIE/mSATA uses a corner screw.
Spencer Martin Navarra Chew -
Yes, there is an M.2 SSD slot on the left side of the motherboard. I’ve installed a 256GB SSD in the slot on my VT21
Bill Scharf - 回复
No, it’s clearly an mPCIE/mSATA slot, not m.2. The pin/notch configuration and retention screw position make it easy to identify.
You must be using a mPCIE or mSATA SSD.
Spencer Martin Navarra Chew is correct about this slot. My mistake.
Bill Scharf -
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 44
总计 5,375
