跳转到主内容
Sony Vaio Tap 11 Solid State Disk Replacement
你所需要的
  1. Sony Vaio Tap 11 Solid State Disk Replacement, Screen Assembly: 步骤 1 中的图像 1,1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Solid State Disk Replacement: 步骤 2 中的图像 1,1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Solid State Disk Replacement: 步骤 3 中的图像 1,2 Sony Vaio Tap 11 Solid State Disk Replacement: 步骤 3 中的图像 2,2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Solid State Disk Replacement, Solid State Disk: 步骤 4 中的图像 1,1
    • Unplug the battery connector located beside the fan.
    • Locate the SSD on the right side of the device, above the battery and beneath the WiFi chip.
  5. Sony Vaio Tap 11 Solid State Disk Replacement: 步骤 5 中的图像 1,1
    • Remove the two 3 mm Phillips #000 screws from the right edge of the SSD.
  6. Sony Vaio Tap 11 Solid State Disk Replacement: 步骤 6 中的图像 1,2 Sony Vaio Tap 11 Solid State Disk Replacement: 步骤 6 中的图像 2,2
    • Pull the SSD towards the right and slightly up, removing it from the back assembly.
结论
3等其他人完成本指南。
Alexander Bridges
于09/16/15注册
1,217 声望
创作了7篇指南
团队
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G2
4 名成员
创作了20篇指南
3条评论
What kind of M2 Type? SSD is needed for replacement/upgrade?
Marius - 回复
OK, found the answer, it's mSATA, like the Samsung 840 EVO Series:
http://www.samsung.com/us/business/suppo...
Marius -
I did the same without pulling out the battery jack. As i tried to turn the tablet on it didn’t work. Even the fan stopped working. I inserted the power cable but no response .. nothing at all ! Please help!
ib_1990_ib - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 18
总计 5,962
