跳转到主内容
加入维修社区 - 创建账户
Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
你所需要的
    1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: 步骤 1 中的图像 1,1
      • Begin by opening the HDMI/USB port cover on the left edge.
      • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
      询问修复机器人
      添加评论
    2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 2 中的图像 1,1
      • Locate and open the Micro SD slot on the top side of the device.
      • Remove the two screws located beneath the cover.
      询问修复机器人
      添加评论
    3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 3 中的图像 1,2 Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 3 中的图像 2,2
      • Attach the suction cup to the top right area of the screen.
      • Pull to separate the screen from the rest of the device.
      • Be aware of the front camera cable that is still connected to the rest of the device.
      • Detach the display ribbon cable.
      添加评论
    1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: 步骤 4 中的图像 1,1
      • Flip device upward carefully like you are turning the page of a book.
      询问修复机器人
      添加评论
    2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 5 中的图像 1,1
      • Disconnect the camera cable from the device backing.
      询问修复机器人
      添加评论
    3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 6 中的图像 1,1
      • Remove the single 3 mm Phillips #000 screw on the left side of the module.
      • Remove the module from the front panel assembly.
      询问修复机器人
      添加评论
结论
取消:我没有完成这个指南。
另外一个人完成了本指南。
团队
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G2
4 名成员
创作了120篇指南
1指南评论
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 14
过去 30 天: 34
总计 1,393
