跳转到主内容
Sony Vaio Tap 11 Screen Camera Module Replacement Replacement
你所需要的
  1. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Assembly: 步骤 1 中的图像 1,1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 2 中的图像 1,1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 3 中的图像 1,2 Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 3 中的图像 2,2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement, Screen Camera Module Replacement: 步骤 4 中的图像 1,1
    • Flip device upward carefully like you are turning the page of a book.
  5. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 5 中的图像 1,1
    • Disconnect the camera cable from the device backing.
  6. Sony Vaio Tap 11 Screen Camera Module Replacement Replacement: 步骤 6 中的图像 1,1
    • Remove the single 3 mm Phillips #000 screw on the left side of the module.
    • Remove the module from the front panel assembly.
结论
另外一个人完成了本指南。
团队
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G2
4 名成员
创作了20篇指南
1指南评论
Is it possible to replace the camera module with a different one? I think that it is a usb camera. I would like to replace it a newer sony model.
Matthew Harper - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,056
