跳转到主内容
Sony Vaio Tap 11 Power Jack Replacement
你所需要的
  1. Sony Vaio Tap 11 Power Jack Replacement, Screen Assembly: 步骤 1 中的图像 1,1
    • Begin by opening the HDMI/USB port cover on the left edge.
    • Remove the three #000 headed, 3 mm long screws located underneath the port cover.
  2. Sony Vaio Tap 11 Power Jack Replacement: 步骤 2 中的图像 1,1
    • Locate and open the Micro SD slot on the top side of the device.
    • Remove the two screws located beneath the cover.
  3. Sony Vaio Tap 11 Power Jack Replacement: 步骤 3 中的图像 1,2 Sony Vaio Tap 11 Power Jack Replacement: 步骤 3 中的图像 2,2
    • Attach the suction cup to the top right area of the screen.
    • Pull to separate the screen from the rest of the device.
    • Be aware of the front camera cable that is still connected to the rest of the device.
    • Detach the display ribbon cable.
  4. Sony Vaio Tap 11 Power Jack Replacement, Battery: 步骤 4 中的图像 1,1
    • Disconnect the battery from the motherboard by pulling out the cable below the fan.
  5. Sony Vaio Tap 11 Power Jack Replacement: 步骤 5 中的图像 1,1
    • Remove the seven 3 mm Phillips #000 screws that hold the battery in place.
    • Carefully remove the battery from the back assembly.
  6. Sony Vaio Tap 11 Power Jack Replacement, Power Jack: 步骤 6 中的图像 1,1
    • Remove the two 3mm Phillips #000 screws from the bottom left corner of the device.
  7. Sony Vaio Tap 11 Power Jack Replacement: 步骤 7 中的图像 1,1
    • Unplug the jack from the motherboard.
  8. Sony Vaio Tap 11 Power Jack Replacement: 步骤 8 中的图像 1,1
    • Remove the metal covering.
  9. Sony Vaio Tap 11 Power Jack Replacement: 步骤 9 中的图像 1,1
    • Pull out the cable and jack assembly.
结论
3等其他人完成本指南。
Alexander Bridges
于09/16/15注册
1,217 声望
创作了7篇指南
团队
IUPUI, Team 1-2, Harley Fall 2015 IUPUI, Team 1-2, Harley Fall 2015 的会员
IUPUI-HARLEY-F15S1G2
4 名成员
创作了20篇指南
2条评论
I wonder if you have the part number or can supply this power jack?
James Toal - 回复
Yes, Where can I find this replacement part?
mikebeard65 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,812
