简介
This guide will provide detailed information in regards to the internal speakers and how to replace them. This may be necessary if there is any issue with sound volume or quality from the device that isn't present when using headphones.
你所需要的
Begin by opening the HDMI/USB port cover on the left edge.
Remove the three #000 headed, 3 mm long screws located underneath the port cover.
Remove the four 3 mm Phillips #000 screws from the upper and lower ends of each speaker module.
另外一个人完成了本指南。
