跳转到主内容
Sony Vaio SVT151A11L Multimedia Card Reader Replacement
你所需要的
  1. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 2 中的图像 1,3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 2 中的图像 2,3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 2 中的图像 3,3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Back Panel: 步骤 3 中的图像 1,3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Back Panel: 步骤 3 中的图像 2,3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Back Panel: 步骤 3 中的图像 3,3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 4 中的图像 1,3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 4 中的图像 2,3 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 4 中的图像 3,3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
  5. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Multimedia Card: 步骤 5 中的图像 1,1
    • Get unobstructed access to the multimedia card.
  6. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 6 中的图像 1,2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 6 中的图像 2,2
    • Unscrew the two 2mm screws from the board using JIS #0 screwdriver.
  7. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 7 中的图像 1,2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 7 中的图像 2,2
    • Lift up multimedia card.
    • Pull out ribbon cable from connected board.
  8. Sony Vaio SVT151A11L Multimedia Card Reader Replacement, Multimedia Card Reader: 步骤 8 中的图像 1,1
    • Get unobstructed access to the multimedia card reader.
  9. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 9 中的图像 1,2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 9 中的图像 2,2
    • Unscrew three 2mm screws using JIS #0 screwdriver.
  10. Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 10 中的图像 1,2 Sony Vaio SVT151A11L Multimedia Card Reader Replacement: 步骤 10 中的图像 2,2
    • Gently lift up multimedia card reader.
    • Pull out ribbon cable from the board.
结论
团队
UMass Dartmouth, Team S4-G6, Julie Fall 2017 UMass Dartmouth, Team S4-G6, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G6
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 9
总计 447
