跳转到主内容
Sony Vaio SVT151A11L Back Panel Replacement
你所需要的
  1. Sony Vaio SVT151A11L Back Panel Replacement, Battery: 步骤 1 中的图像 1,2 Sony Vaio SVT151A11L Back Panel Replacement, Battery: 步骤 1 中的图像 2,2
    • Flip the laptop over so that the battery on the underside of the device is revealed.
    • Unscrew the two 11mm slotted silver screws that can be found at the top of the battery.
  2. Sony Vaio SVT151A11L Back Panel Replacement: 步骤 2 中的图像 1,3 Sony Vaio SVT151A11L Back Panel Replacement: 步骤 2 中的图像 2,3 Sony Vaio SVT151A11L Back Panel Replacement: 步骤 2 中的图像 3,3
    • Wedge the plastic opening tool between the back panel and the battery on the top left side of the device.
    • Push down on the plastic opening tool until the battery lifts from the back of the laptop.
    • Grab the battery and remove it from the device.
  3. Sony Vaio SVT151A11L Back Panel Replacement, Back Panel: 步骤 3 中的图像 1,3 Sony Vaio SVT151A11L Back Panel Replacement, Back Panel: 步骤 3 中的图像 2,3 Sony Vaio SVT151A11L Back Panel Replacement, Back Panel: 步骤 3 中的图像 3,3
    • Unscrew the three 4mm screws using a JIS #0 screwdriver.
    • Unscrew the eight 7 mm screws using a JIS #0 screwdriver.
    • Grab and lift the edge of the panel to pull it free from the rest of the computer.
  4. Sony Vaio SVT151A11L Back Panel Replacement: 步骤 4 中的图像 1,3 Sony Vaio SVT151A11L Back Panel Replacement: 步骤 4 中的图像 2,3 Sony Vaio SVT151A11L Back Panel Replacement: 步骤 4 中的图像 3,3
    • Grab the disk drive located at the edge of the computer and pull it it out.
    • Unscrew the three 7 mm screws with a JIS #0 screwdriver.
结论
团队
UMass Dartmouth, Team S4-G6, Julie Fall 2017 UMass Dartmouth, Team S4-G6, Julie Fall 2017 的会员
UMASSD-JULIE-F17S4G6
2 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 14
总计 1,149
