跳转到主内容
加入维修社区 - 创建账户
Sony Vaio SVE171C11L RAM Replacement
你所需要的
  1. Sony Vaio SVE171C11L RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so its underside is facing upwards and visible.
    询问修复机器人
  2. Sony Vaio SVE171C11L RAM Replacement: 步骤 2 中的图像 1,1
    • Once you flip the laptop over, make sure the right tab is pushed upwards to unlock it.
    • Use your left hand to push up the left tab to release the battery.
    询问修复机器人
  3. Sony Vaio SVE171C11L RAM Replacement: 步骤 3 中的图像 1,1
    • After the battery is released, locate the small gap where the battery and the shell meet. Then lift the gap up and rotate the battery up and away from yourself.
    询问修复机器人
  4. Sony Vaio SVE171C11L RAM Replacement: 步骤 4 中的图像 1,1
    • Pull the battery away.
    询问修复机器人
  5. Sony Vaio SVE171C11L RAM Replacement, RAM: 步骤 5 中的图像 1,1
    • Unscrew the single 3mm screw to remove the RAM panel.
    询问修复机器人
  6. Sony Vaio SVE171C11L RAM Replacement: 步骤 6 中的图像 1,1
    • Use both hands to unlock the clips that are securing the RAM.
    • The RAM will pop out from the slot when release the clip. After unlocking, slide out the RAM from their slots.
    • When inserting new RAM do not forget the put the clips back on.
    询问修复机器人
结论
另外一个人完成了本指南。
团队
CSU Los Angeles, Team 6-3, Adachi Fall 2022 CSU Los Angeles, Team 6-3, Adachi Fall 2022 的会员
CSULA-ADACHI-F22S6G3
3 名成员
创作了13篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 46
总计 486
